Opel Insignia 2.0 cdti 160hp fuel pump pressure problem
Hi for all need your help
I have here in my garage an Opel insignia with a high fuel pressure problem !
P0088 - Fuel pressure high on fuel pipe
Desired pressure : 300 bar
Actual pressure : 1600 bar
Injector leak testes good , new pump and new pressure sensor and not solve .
Anyone ever had a problem like this ?
Thx
We can and must help each other on special occasions, but in the end everyone must learn from their work  Wink
If i help you , please press thanks and rep  Handshake
The pressure increases from 0 to 1600?
At idle is 1600? the engine it stops?
can be a clogged fuel return line
the pressure drops when accelerate ?
put here the bosch number for hp pump
don't forget to hit thanks and reputation buttons
Thanks given by: marcoandre23
(03-18-2025, 06:55 PM)Bogdan Beb Wrote: The pressure increases from 0 to 1600?
This car sometimes start normally and show at idle 1600 bar . When i acelerate show normal desire values. When drop to idle go to 1600 +- and sometimes shut down and knocking like a problem in fuel regulator
My pump is 0445010248 and its new
Injetors repaired . Same problem . Anyone ??
Did you  tried to remove the fuel return hose from engine and put a new hose in fuel pump  in a bottle to see if there is a change in pressure?
Try this to see if all the return system is not clogged somewhere.
05-28-2026, 01:42 AM
05-22-2026, 03:30 PM
