111
Thanks Given: 1831
Thanks Received: 576 (298 Posts)
1,360
175
Have an opel Insignia 2011 A20DTH with a problem with the haldex clutch. Parts are very expensive and the owner will deactivate the 4WD
Is there an option do disable the 4WD without message in cluster ?
129
Thanks Given: 386
Thanks Received: 294 (128 Posts)
538
94
i need same solution
When it helps you, Click Thanks and Reputation
mip
Location OfflineJunior Member
280
Thanks Given: 17
Thanks Received: 387 (38 Posts)
111
Have you MDI?
Wysłane z mojego LYA-L29 przy użyciu Tapatalka
Thanks Given: 762
Thanks Received: 60 (54 Posts)
318
40
Is it poseable to disable 4wd or not? I have a MDI
mip
280
Thanks Given: 17
111
From cluster should be
Send me PM
0
Thanks Given: 1
Thanks Received: 0 (0 Posts)
0
Help please .
Same problem how to disable without error message.
Thank you.
27
Thanks Given: 40
Thanks Received: 60 (27 Posts)
125
I CAN SOLVE THE PROBLEM
SEND A MESSAGE
- ALLDATA EU/USA - HAYNES PRO - MİTHCELL PRO DEMAND - FDRS İDS LİCENSE - FORD ACCOUNT - GM SPS - FİAT EPER -
