Opel Insignia - Side object detection programming doesn't work
Hi.
I've replaced RH (slave) side object detection module with a used one (from other vehicle).
As expected, I've got "not programmed" DTC, which is OK
[Image: pasted-file-i1-Avya.png]
I've programmed it using SPS2, which succeeded
[Image: pasted-file-4-WWRaa.png]
But... the module still doesn't work. After clearing DTCs, waiting 5 minutes and turning the ignition on again, the B101E is still there...
I've noticed that one of the modules reports id "0000000". Is this the way it's supposed to? Should the identifier be "0"?
[Image: pasted-file-w9ot6i.png]
[Image: pasted-file-8a-Xabx.png]
90% left radar water damage
I can reprogram correct but without garanty
Activation GDS2 Opel, Chevy, Saab, Global
Help with SPS. Activation-deactivation any options.
hmm.. right radar was indeed damaged (that's why I replaced it) but left one is in pristine condition
Quote:I can reprogram correct but without garante
do you know what I did wrong in the re-programming? do I need sth special?
seems the model is broken
(05-31-2024, 11:41 PM)djdanny Wrote: hmm.. right radar was indeed damaged (that's why I replaced it) but left one is in pristine condition
write me to pm at monday
06-12-2026, 06:29 PM
06-01-2026, 10:52 AM
