Opel Insignia need wiring diagram
10
(06-26-2024, 12:59 PM)goontii Wrote: Top of battery? No module is there. Only main fuse box and Engine control module
That what you think that is ECM is K124 Smile
Thanks given by: goontii
11
Maybe I send you photo from my car. I dont see that. But your photo looks like trunk from car, not front under hood
I attached photo
Yap, sorry, my fault. It's not above battery it's in the trunk under cover. You got there suspension module, trailer module, video proccessing module and active safety module.
No problem. But more funniest thing is that than in all trunk space I dont have any module Smile Car is manual gearbox, no trailer. Probably in my car no have ACSM
BCM and Reflector unit show problem communication with camera. Maybe camera in not good, but I change camera and reprogram it. The same. Maybe number of camera for car with front radar is diffrent than camera for car without front radar. VIN number says that car have radar or no? The car was bought with a burnt harness and camera. Now I have two camera with number 84467084 and 84225594
Front camera for your VIN is
  • 84252902
  • 84565029
  • 84646909
  • 84467084
Everything is same camera just different part numbers.
15
Friend Artifact thanks a lot of for your help. Now I need someone who help me with diagnose this car remotly. Because i check wiring and change front camera but still have error on dash (leveling reflector, camera fault). Bcm and reflector not see front camera. Diagnostic tool communicate with fcm without problems. In camera I have only one dtc, calibration not finish
You need to run calibration and go for 45 drive min as I remember.
Yes I do this but calibration not working. Not recognized sign traffic and show check front camera. But I find corrosion in bcm on board. Probably this is the problem.
Unfortunately not help. I change bcm but the same
05-28-2026, 01:42 AM
05-22-2026, 03:30 PM
