PabloMo
Location OfflineJunior Member
0
Thanks Given: 58
Thanks Received: 0 (0 Posts)
73
15
Hey Guys
I Need to read and maybe reset the Adaptation values(Gearbox) from an Insignia A.
Which Software is used from Opel and is there an Cheap Adapter?
chobra
0
Thanks Given: 52
Thanks Received: 1 (1 Posts)
14
It's best to take the VCXnano and the GDS2 software for the adapter is around €110 , Software can you find here
Thanks Given: 7
Thanks Received: 23 (22 Posts)
138
an J2534 device and GDS2 is ok
PabloMo
0
Thanks Given: 58
73
15
I tried with Openport Tactrix J2534 but it Said its Not supported and Connection is Not possible
281
Thanks Given: 22
Thanks Received: 443 (73 Posts)
140
PM me i help you out
Please Leave Rep + Thank You if I helped you.
BMW programming + All key lost solution
Mercedes programming, AMG menu, CARPLAY
Range rover Topix + Pathfinder
Ford IDS, FJDS, FDRS original license, PATS login
GM +Opel online programming
Toyota
enyckma
0
Thanks Given: 91
Thanks Received: 5 (3 Posts)
0
Sm2pro China clone v2.22 works good with gds2....
