Opel Meriva EASYtronic P1735
Hy i have an 2007 opel meriva. I have changed GEARS Aktuaktor with an known working one and tried to Learn gearbox parameters but it stuck always at 1 Gear i checked the gears but they are smoth . Can someone help me and learn my eeprom file or give me working eeprom file. Engine is Z16XEP Easytronic ecu number is 1208067 BF
Thank you in advance
M24C16.rar
628 bytes
Well as I know you can do it easy with opcom
(04-21-2024, 09:46 PM)mm04kk Wrote: Hy i have an 2007 opel meriva. I have changed GEARS Aktuaktor with an known working one and tried to Learn gearbox parameters but it stuck always at 1 Gear i checked the gears but they are smoth . Can someone help me and learn my eeprom file or give me working eeprom file. Engine is Z16XEP Easytronic ecu number is 1208067 BF
First of all what tool you work? Can you tell the trouble code which shows when doing the relearn?
How you check the gears?
I use OPCOM, and i checked the gears with scremwdriver every gear is engaging and disengaging smotthly and not stucking. I also tried with different Gears aktuaktor which are 100% working on other car. But always when i start learning Baseposition is done good then 1st gear engaging and then stucks in first gear. Then i try second time and comes out from 1st gear then engaging 1st gear and stucks and gime me timeout error.
My problem was the first GEAR Shift FORK
Thanks given by: matys225 , morfej
Opel
03-14-2026, 12:58 PM
01-18-2026, 07:42 PM
01-06-2026, 10:49 PM
