Opel Vectra B 2.0DTI neer ori file
Hi there!
So i have a Opel Vectra B with the 2.0DTi engine, i need to do egr off on the car, however it hás EDC15M ECU, with mpps and kess i can ONLY write and ID, Parte number is 90508986 and it is a manual transmission X20DTH
(06-13-2026, 04:52 PM)Nightkid08 Wrote: Hi there!
here you go
Opel_Vectra_B_2.0d_X20DTH_1998_101hp_Bosch_0281001633_90508986_Original.rar
84.3 KB
Thanks given by: Nightkid08
here you go
Thanks a lot, for egr off wich software can i use? Thanks you!
here you go
No one. Manual solution here. Test it and report back.
You can unplug the plug of EGR valve and tap It`s  vacuum line with something. Also, you can buy EGR plate for this engine from Tafmet.pl.
Watch out, cause there are two versions(steel and "plastic" egr)
Password after thanks and rep.
If you need remap, i can do superb one.
0
84.23 KB
9 hours ago
06-14-2026, 08:56 PM
06-14-2026, 08:47 PM
