Opel Vivaro II B 1.6 Biturbo P2263 Fault
10
(10-31-2024, 11:59 AM)georgegu50 Wrote: Hi! i have an opel vivaro b 1.6 2016 with same problem P2263 no boost, everything was checked turbo, vacum, solenoids, dpf is removed, maybe is posible to do something from ecu, or dump is corupted.
i attach full dump, ecu is edc17c84
https://easyupload.io/db5hlc
thanks in advance!
Before that problem the clutch-pedal switch was faulty and the car has no power/no boost. After replaced this part the car got the power/boost back...
Then the car was driving well then but still got the DTC sometimes (maybe boost too high peak for a second ?). (Only DTC and error on dash but luckily no power loss and no limp mode).
05-24-2026, 04:18 AM
05-19-2026, 12:14 PM
04-27-2026, 11:43 PM
