Opel signum wrong immo pin code how to change it with Tech2
Hi i have opel signum 3.2 v6 z32se and tryed to swap new ecu on it with tech2 and globaltis,
everything went ok till i entered the wrong ecu pin code i put the new ecu pin code not the car pin code Sad
is there any way to start the programming again or reset the new ecu so i could enter the pincode again?
i cant program it again cos globaltis says its allready the latest version.
theres error code for the immo, how can i change the pin code for the immo to right one?
You got parametar in Tech2 Security wait time or something like that. Car need to be on ignition for 10/20/40 min depends on what is writen on diagnostic
I can provide wiring diagrams, parts number, technical service bulletins, part replacement procedures etc.. for Citroen/Opel. No pin code or key cut codes.
As another member told you - check for security wait time. If global tis shows that already nevest calibration then you do not need to flash ecm at all with globaltis. Use opcom or tech 2, reset donor ecm with donor pin, and program ecm with car pin. Good luck Smile
Ok now i got it havent thought about the wait time thanks, ill try opcom it seems easier to reset the ecu.
06-09-2026, 08:15 PM
06-09-2026, 06:54 PM
06-02-2026, 10:00 PM
