  • 1 Vote(s) - 5 Average
PATS OFF FOR EEC V Calculator
Good Morning dear Friends of MHH AUTO FORUM,
after some months of resourcing i made a Calculator for get immo off in all Ford´s EEC V PCMs, this work come from all the info that EECV FREE PROJECT upload in his repository but i focus only in the immo part because is the principal service that we need to offer here in my country,
We found around 15 flags in control of PATS but we define only three that are the principal so we made a calculator for turn off those flags, a simple as it sound.
the calculator is simple,
1 upload the file.
2 select if the transmission is auto or manual.
3 click in ¨Desactivas PATS¨ button.
the file will save in the carpet with some IMMO_OFF Label and is all.
this calculator works fine in some EEC Vs that we tested but there only a few because we work with somes we have and some others of clients but it needs been tested in some more for get comfirm that is this it the magical formula or need to add some more flags for others EECVs so we like to have feedback from you people from MHHauto, this thread will be my feedback and if you have some file of a eecv that the immo works  i hope can you reports back and if not too so we can get better the formula.
this Soft will be free for ALL!!!!!!! and in final terms will be upload everything in my repository.
Disclaimer:
[font=Mona Sans VF", -apple-system, BlinkMacSystemFont, "Segoe UI", "Noto Sans", Helvetica, Arial, sans-serif, "Apple Color Emoji", "Segoe UI Emoji]This software and source code are designed and intended EXCLUSIVELY for study, research, technical diagnosis, and equipment repair purposes.[/font]
[font=Mona Sans VF", -apple-system, BlinkMacSystemFont, "Segoe UI", "Noto Sans", Helvetica, Arial, sans-serif, "Apple Color Emoji", "Segoe UI Emoji]The methods and addresses shown here are the result of research and reverse engineering for educational and development purposes.[/font]
[font=Mona Sans VF", -apple-system, BlinkMacSystemFont, "Segoe UI", "Noto Sans", Helvetica, Arial, sans-serif, "Apple Color Emoji", "Segoe UI Emoji]This tool is intended for use in repair processes, test benches, and personal projects only.[/font]
[font=Mona Sans VF", -apple-system, BlinkMacSystemFont, "Segoe UI", "Noto Sans", Helvetica, Arial, sans-serif, "Apple Color Emoji", "Segoe UI Emoji]The author is NOT responsible for misuse, illegal use, or any damage caused by this software. The end user is solely responsible for complying with their local laws and regulations.[/font]
.txt
PATS_OFF_EECV.txt
177
120 bytes
PATS OFF CALCULATOR FOR EVERY FORD EEC V IN MY PROFILE, PLEASE CHECK AND GIVE FEEDBACK
¨there is no knowledge that is not power¨
-Mortal Kombat
(04-09-2026, 05:49 PM)AutoelectricoStBeni Wrote: Good Morning dear Friends of MHH AUTO FORUM,
1 upload the file.
Disclaimer:
Thanks for the great work! Do I need to upload flash or EEPROM data?
If it's flash, do a checksum afterwards.
1 upload the file.
Disclaimer:
work it on flash, regards the eeprom in those PCMs in tending to get damaged and that motivate me to do this work but in some PCMS where the EEPROM is too damged not work, but if still read a least garbage it works great.
regarding that the reading of those PCMs is mostly in PCMflash Module 29 and the soft do the checksum we decided not implement checksum check but maybe later, in beta version we implemented but is better keep it simple, the flags are not in the injection map so not worry though.
enjoy and please give feedback.
-Mortal Kombat
Thanks given by: danielif , schmango , Roturbo , pepepe2000
Hallo, unterstützt Ihr PATS OFF-Rechner dieses Ford Explorer 4.0 V6 EEC-V Steuergerät?
Teilenummer: F87F-12A650-AYB
Hardware: ML2-463
Fangcode: ACQ1
Strategie: QAAC4
Software: QAAC4C6
Ich habe eine 224 KB große BIN-Datei, die mit KESS3 eingelesen wurde.
Danke schön!
post here your file and i can make pats off by this soft and you can check ith.
Do not forget to press Thanks and Reputation buttons...
(10-05-2026, 12:00 AM)lipton8111 Wrote: Hallo, unterstützt Ihr PATS OFF-Rechner dieses Ford Explorer 4.0 V6 EEC-V Steuergerät?
Hardware: ML2-463
Fangcode: ACQ1
Strategie: QAAC4
Software: QAAC4C6
Danke schön!
can not understand sorry not know the lenguage, this soft is intended for eec v 104 pins all those PCMs generation share the same micro so the flags found in that micro are the key for desactivate PATS, if the your PCM is the same  of those maybe can work, i know by now that are some others EEC V from diferents PINS and those never tested with these calculator so if somebody try please give feedback. the proyect is freeze the feedback is poor, some report back that works other said that not work but no share the info of the pcm for resorce and get better the tool so is dificult work like that.
i have other calculator for the others so if you have the file (flash)can try, Free of course.
-Mortal Kombat
Thanks given by: PierreTheron
Hardware: ML2-463
Fangcode: ACQ1
Strategie: QAAC4
Software: QAAC4C6
Danke schön!
I tried your app but it did not work. 2003 Ford ranger 3.0L 4x2 automatic transmission. 104-pin EEC V pcm.
Here is the flash file read with pcmflash module 29.
new pcm good vin new read.rar
130.72 KB
Old ford pcm
Users browsing this thread: teckie2
