(01-24-2023, 08:18 AM)kal Wrote: Look after you attempt to start it the security list solid or flashing? After 10 minutes there is no change? Flashing to solid or light out? Did you check the vin in the PCM? Something doesn't seem right in your programming I thought I saw it said a total of four keys learned? Have you tried a different key? If all this checks out I would do a one-to-one copy with PCM hammer just to make sure. Vtd from tech2win should have done the trick so I'm wondering if something is corrupt. Last thing I would say is sometimes you have to do a battery reset before you try it because of things being jammed up.
When ignition is ON security light solid constant. After 10 minutes no changes. Still solid constant. (manulal procedure reLearn keys dosen't work
)VIN in PCM after SPS programing is now correct -the same like VIN on chassis.
4 keys in VTD are storage - data read by Tech2win
I have only one key..for this car. But I've ordered new blank key with blank tranponder. I will recive it in Friday.
"PCM hammer just to make sure" - KAL - old PCM is dead. No comunication via OBD and bench mode. This is reason why I bought used module and done SPS VIN programing.
Battery was reset few times.
Tech2will allow to do SpecialFunction for VTD like "new Run" but after this no changes. Still the same, Info on dash "starting disabled remove key..."
SPS for VTD dosen't work..
As i wrote, now I wairing for a package with new blank key..
But if you have another idea please share it
