  • 8 Vote(s) - 2.13 Average
PCR 2.1 DPF SOLUTION
Hi. I used DPF REMOVER from Luis to make dpf off on PCR 2.1,errors goes off and with diagnostics all it's ok,but i have black smoke and 1000 rpm at idle . Anyone can check this solution?Thanks!
post your dtc and original file , i will made dpf off + dtc off
tuning file service 7/7 Skype
BLACK smoke are not the problem from the DPF!!
Butt the dpf is not good removed
100% MANUAL TESTED AND WORKING SOLUTIONS!!
EGR/DPF\DTC/SWIRLFLAPS/CAT\ADBLUE/LAMBDA//....OFF FILE SEVICE!!
//DYNO CHIPTUNING FILESERVICE!!\\
Skype: RULES...........................
Original it's posted.With my solution i don't have dtc ,only smoke and idle problem.Thanks!
I'm confused because everyone who used DPF Remover for this type of ECU, says it works (I have searched on forum)And now i don't know if it's software problem or mecanical problem.
Did you reset dpf??? Before off??
working solution
no cheksum
Seat_Ibiza_1.6_nodpf_no_chk.rar
110
102.52 KB
bcm2 elv adapt online -echange immodata -clone immodata sinchro bcm elv medc17 edc17 -DPF/ EGR/ DTC/ removal/: IMMO ADAPT edc15 edc16 EDC17 edc17c64 NOW WORKING MED17/MEV17/ VAG ecu clone full working all
prc2.1 adapt, clone, etc / dash with micronas ou nec echange immodata etc etc
Thanks given by: Andrea901 , maateusz66
what cause this 1000 rpm idle? many thanks
7 hours ago
Fiat
Yesterday, 08:35 PM
06-12-2026, 11:19 PM
