PCR 2.1 egr/dpf off rate
can somebody please check this egr-dpf off solution?
***I don`t need another solution , just file rate.
with this file car have 1000 rpm idle and intermitent (rare) diesel in oil.  I don`t know if is due to the file , the car had this problem before.
beside this ,no smoke , no dtc , no peformance issues.  before writing dpf reset was done.
many thanks
file is ok, try to reset DPF ash with odis
and make sure the DPF itself is emptied
it shouldnt be at 1000rpm at idle and fuel shouldnt be goin to oil
so after your reset dpf ash grab a multimeter and check the battery voltage when its idling , should be about 13.5v or more , less means weak battery or alternator
and check voltage while cranking
Thanks given by: euromod
many thanks mate.  I don`t have the car anymore for testing , I refound the costume after writing back the ori file.  with ori file , idle was ok , not 1000 rpm ...
If I remeber well , after unlocking the ecu via ktag , I wrote the mod file via kess in obd bench mode and after the ecu was remounted on the car I reset dpf.
maybe I performed a dpf reset before removing the ecu for unlocking but I`m not sure.
what is the worst scenario if the dpf reset is not done?   for me is the first pcr with issue , other similar cars were all ok.
many thanks again
06-13-2026, 05:47 PM
06-13-2026, 03:47 AM
