(11-14-2026, 12:56 AM)mobialtech Wrote: Now i tryed too, unlock pcr2.1. First read the eeprom, opened in whit hex editor, all file ist 00 00 00 00....
The 90% of problems related with PCMTuner are caused by too low voltage supplied to the ECU. With the PCMTuner stock setup the bench wires are too thin, the max input voltage of PCMTuner is less than 14v and the provided power suply is china crap. I strongly recommend to do your own set of wiring harness. Make a high quality bench power harness with 14GA, use at least 10A, 14.4v quality power supply. As I said before, the PCMTuner will be burned if you provide 14.4v to it, so you can make a custom power harness that goes from power supply direct to ECU, and at the same time from power supply -> 12.0v voltage regulator -> PCMTuner. For the bench data wires use high quality silicon wires of 22GA, not stock 28GA. Put a low voltage drop diode 1N5822 on each ignition (positive) wire to avoid returns.
In the case of OBD harness, do the same. You can't allow 14v to the PCMTuner from the car, so you can cut the D-SUB DB25 connector, and put a 12.0v regulator between the power wires and the D-SUB DB25 connector. OBD power wires are Pin 16 (positive) and Pins 4 & 5 (negative).
See attached pinouts ONLY FOR PCMTuner.
It's the way to have a reliable tool, specially if you are thinking to buy the new china dongle with PCMFlash version 1.39 from year 2025.
