  • 3 Vote(s) - 1.67 Average
PTT 2.6 PROBLEM
All is good now.
(06-01-2018, 12:27 AM)trs100 Wrote: Hi,
I purchased ptt 2.6 from chestertech and was OK first few times.
Then it showed the message as on the picture?
I asked chestertech, he promise to do it, but more than a month since then he don't answer.
Can you help me guy, what could be the reason for it and how to fix it?
Also if you have some info for chestertech let me know
Thanks.
looks like you have changed from metric to us
now you have to reactivate it again and keep it at metric.
Before reactivation stop services.
Thanks given by: quality truck
Yes. Same thing with my Chestertech install.
I am just a mechanic, I will help if I can to pay back this awesome site!
All good and fixed.
(06-01-2018, 01:23 AM)trs100 Wrote: He said he is going to reactivate, because I need it in USA units.
But he just never came back.
Is there anything I can do to fix it?
He can't make it to work in miles. He needs to adjust the databases (apci and baldo) in miles. His 2.05.87 NEVER WORKED with north American trucks. As far as I see from this thread, his 2.6 isn't working either. Look, I'm new here. I'm not bashing Chestertech, he shared a lot of good things on this forum and I have nothing but RESPECT for him. But his 2.5 and 2.6 installs DO NOT and WILL NOT work with north American trucks. There's only one guy in the whole world at the moment who has a 2.6 install that will work with us trucks, and that is suskunx aka phoenixdiags. Don't waste your time. I did, I spent months of my life trying to make it work. Don't be me, be smarter
Volvo PTT 2.7 Developer in miles for USA trucks - Developer tool - Visfed
Subaru Select Monitor 4 - 2019
Xentry 09.2019 - WIS - EPC
Toyota Techstream
Toyota Supra 2020
ODIS D+E
Jpro 2019 V2
Thanks given by: quality truck , ivecoman4 , ray-san
Is more then one Member here who can install 2.5.87 and work on US trucks.I work fev days ago on 2015 vn and ver 4 Mack,also on ver2.No problem at all.No vocom requided.Regards!
(06-01-2018, 09:02 AM)silnoreki Wrote: Is more then one Member here who can install 2.5.87 and work on US trucks.I work fev days ago on 2015 vn and ver 4 Mack,also on ver2.No problem at all.No vocom requided.Regards!
If they know how to change the databases then yes, is possible. I didn't see it on the forum tho, the only 2.5 I've seen in the open with Chestertech activation does not work with us trucks. In km works, as soon as you change to miles it gives that baldo error message. I've also seen shops that use it in km on us trucks.
Toyota Techstream
Toyota Supra 2020
ODIS D+E
Jpro 2019 V2
Mr. Chestertech share own work for all,is not easy to install,but many issues is while other software installed,bad procedure,OS loaded with lot of crap.I trial myself and spend long,hard time,reinstall win many times.Finally find one of Member who spend another hard time helping Me to get work.After that I test on trucks and work as should.What suprising Me is inline7 for some reason does work,network bridge connect fast with all electrical systems without problems thru 9pin to obd.Regards!
30 minutes ago
7 hours ago
Today, 03:02 AM
Volvo
Yesterday, 10:00 PM
Volvo
Yesterday, 05:45 AM
