I have a Passat B5.5 2004, engine BGW, ECU Bosch EDC16U31. Trying to read it with KessV2 via OBD but no luck.
What I've already checked:
Worth mentioning that on an Audi A4 B7 with the exact same EDC16U31 it works perfectly via OBD, read/write no issues.
I've read that on Passat B5.5 2004 the gateway / Comfort Control Module might be blocking the CAN bus and preventing Kess from reaching the ECU. Has anyone tried gateway bypass on Passat B5.5 for ECU reading? Does it solve the issue?
Thanks..
- Battery voltage 13.5-14V (charger connected)
- Protocol set manually to BGW/ EDC16U31
- ECU communicates via CAN (not K-Line)
Thanks..
