Payload blankcontroller_ cmu JD
I need to bleach cmu of a 624j john deere loader. Programming failed and I remain null, but it appears on the bus. Secured Payment
(11-11-2019, 04:12 AM)nicolasgancia Wrote: I need to bleach cmu of a 624j john deere loader. Programming failed and I remain null, but it appears on the bus. Secured Payment
ECU_SERIAL_NO=405723
AT312178
ID=DW624JZ608247
You need special PLD file to program "clean" ECU
This PLD can be bought from JD after making proper DTac.
AT312178
ID=DW624JZ608247
How much if you do the dtac and send me payload?
Apsik Wrote:
nicolasgancia Wrote:I need to bleach cmu of a 624j john deere loader. Programming failed and I remain null, but it appears on the bus. Secured Payment
AT312178
ID=DW624JZ608247
Do you still need help with this?
Do you have the original pld you want to program? Do you have a pld editor? Did you try to program it as LOST ECU REPLACEMENT?
Anyway, if you explain exactly what it says when you start programming or better send me the log file from c:sds\logapp I can edit your pld to program anything. Free.
AA JohnDeere
05-22-2020, 09:27 AM
05-18-2020, 02:03 PM
AA JohnDeere
05-15-2020, 06:09 AM
05-08-2020, 12:37 AM
01-29-2020, 11:49 PM
