(03-28-2022, 05:10 PM)DieselSuperStore Wrote:My ESA is Legit as well and have had features enabled numerous times that shouldn't have been.(03-27-2022, 03:49 AM)ejh1 Wrote:(03-27-2022, 01:40 AM)kuracnabiciklu Wrote:(03-25-2022, 04:55 PM)catfan Wrote: Got a Pete with a cm2250 14L that the cab controller has been flashed with the wrong software. Its causing a 0286 multiplexing fault and cruise does not work. The cruise switches show to be working in Insite. Is there a way to get proper flash and parameters for the truck computer with out going to dealer truck is deleted.
Multiplex codes are reported by rhe module that didn't recive the expected signal from the network, in case of cruise control a component that depends on the input it will not work
2 Fix it simply find out what is missing, let's say park brake you need 2 look in insite to see who is reporting rhe signal over the datalink and make sure it's correct then use ESA make sure it's avalible and correct
Why did you disable ABS and Traction? Put it back on
Certain updates enabled Stability and Traction control when the truck was never equipped with it. I'd see if Advanced ABS got active, it uses different Sensors for detecting brake application.
I use legit version of esa and after flash will reset parameters to factory… therefor no traction control issue ….
Otherwise yes
Advanced stability control
Traction control
And sometimes advanced abs system get activated
Thanks given by: catfan
