I have problem with Peugeot 308 1.6 hdi 109HP edc16c34.
The car has removed dpf and tuning was done, but after doing the car the car does not drive almost anything better compared to the series and a lot of consumtion around 11-13l / 100 km.
The car has now saved the original file with dpf and egr disabled without tuning .....
The car has been replaced: turbo after regeneration and turbo control, flow meter, corrections on injectors are normal.
Unfortunately, the car still does not go well ...
Recently, about a year after switching off dpf and egr, a message about a small amount of add-on fap has been shown on dashboard and there is an error in engine ecu from the add-in pump.
I have coded the filter with bsi - the message on the board is gone, but the error in the ecu associated with the add-on remained.
Could you please check these files and help me?
Thank you greetings
I attach the original file from this car, and the file with dpf and egr off after tuning, and the oryginal file with disabled dpf, egr without tuning - this file is now in the car.
Thank you greetings
If I helped - click thanks and give rep
