Please help to buy j2534 eucleia wiscant6 vs scanmatik pro
I am interested in j2534 my decision is between eucleia wiscan t6 and scanmatik 2 pro, i live in the united state i work with toyota, honda, ford, gm, mercedes, bmw, the only thing i see of scanmatik is that it only comes in russian language and the eucleia t6 English and I do not use the Russian language I want something that can earn some money and then buy a cardaq thanks for the help
What interface recomendly only talk english and spanish.
Eucleia wiscan t6 and scanmatik pro
(01-13-2020, 02:48 AM)legendz Wrote: I am interested in j2534 my decision is between eucleia wiscan t6 and scanmatik 2 pro, i live in the united state i work with toyota, honda, ford, gm, mercedes, bmw, the only thing i see of scanmatik is that it only comes in russian language and the eucleia t6 English and I do not use the Russian language I want something that can earn some money and then buy a cardaq thanks for the help
Tatrix Open Port or Abrites can be more useful for you, I guess. But maybe somebody corrects me. Your opinion, great members?
CanTieCar
Does Ford/Mazda  - Forscan
         Toyota        - Techstream
         Honda         - HDS
         Mercedes    - Xentry Passthru
         BMW          - Up till 2008
         GM             - GDS Programming
Any many more
I didn't think scanmatik did Ford??
I use scanmatic 2 pro and it comes with English. l use it with teachstrem , HDS, Mut-3 , Odis .
If I helped you press [Image: thanks.png] and [Image: reput.png]
Thanks given by: skar89
Hi i have  purchased  for testing  the doip S8 eucleia  was at last automechanika frankfurt. I have not tested the j2534 function. and i dont know  what the current  situation is  with the global problem . you can  go here  for  details The  S8 is ok   but the cost function value is to high in my opinion if  you compair  to  launch autel.
http://www.eucleia.net/index.php/English...4/SortID/4
scanmatic 2pro , odis -good , mb - very long scaring - no online coding !!! , toyota work only europe , iveco - 38 pin good , ford and mazda - forscan original software - good work , deawoo and chevrolet immo synk good abs good , china car - good , bmw - NO !!! only icom , bmwscaner , inpa , opps .
For work ecu on table use resistor 120om or 140om can L to Can H
Scanmatic 2 Pro Mut-3
Hello, please help to install the Mut-3 program,
and whether it will work
with the scanner interface and whether it will work
Mitsubishi fuso. Thank you so much.
Thanks given by: Tanner
i want to buy scanmatik 2 pro to use with toyota hilux, mitsubishi l200, ford/mazda ranger bt50.
this interface works ok on MUT III? i see youtube videos, but a lot of vci lite emulator. i need compatibility up to 2020
(06-07-2020, 01:49 PM)engineer.dtc Wrote: Scanmatic 2 Pro Mut-3
ok with  eucleia i think you need  the doip j2534 box and then the problem is manufacturer block non aproofed hardware ,eucleia list some for j2534 passthru but  eucleya  is a  new player and  the product is still in the stage of improofment  and its  no where  near that of the most expensive Autel if  you know what i mean. Also  fuso mitsubishi is listed under  DAS-xentry mercedes in my  tool that also dont  comunicates(xentribox-fault) and i  was going  to see if i could hook up WiScan T6 Pro Diagnostic Programming Tool is based on J2534, PDU and DoIP diagnostic technology. its the tool who comes  with scantab S8 in case.
Yesterday, 01:28 PM
Yesterday, 08:13 AM
Yesterday, 05:42 AM
08-03-2020, 09:43 PM
