Need help calculate smart key code from dump Honda PCX scooter S9S12G64
(02-16-2024, 05:39 PM)Kocurmarcin Wrote: Hi.
Hire are photo of the ecu, keyless module.
It's forza 2019 abd all key lost.
I've got vvdi prog and i think i can read s9s12g64
I've got vvdi mini and can read key Id.
Regards Marcin
(02-27-2024, 06:17 AM)Jimmylamz Wrote: master keyid
257917474
This key id is working OK. I started the bike with YouTube instructions Jimmylamz gave me.
So if someone find this thread useful, thanks and rep to Jimmylamz please.
blue socket is for emergency start . red socket is key learning. i just remembered . i did one today. Big Grin
Thanks given by: Kocurmarcin
12
(03-01-2024, 06:59 PM)Jimmylamz Wrote: blue socket is for emergency start . red socket is key learning. i just remembered . i did one today. Big Grin
Thanks a lot.
It worked as you guided. Hold remote key until led turn red, +12on red socket, put emergency key id like in the video, when it clik, hold remote key until it turns green, and turn ignition on, press remote button, ignition off, remove +12, key programed..
I have 2 remotes programed 😁
CAN ANYONE USE IPROG CALCULATOR SCRIPT FOR THIS ADD KEY FUNCTION? I TRIED BUT IT ALREADY OPENS WITH DATA INCERRED AND I TRIED TO MODIFY IT SEEM TO BE WITHOUT ANY ACTION? HAS ANYONE HAD ANY RESULTS?
(06-27-2024, 03:12 AM)mecadriano Wrote: CAN ANYONE USE IPROG CALCULATOR SCRIPT FOR THIS ADD KEY FUNCTION? I TRIED BUT IT ALREADY OPENS WITH DATA INCERRED AND I TRIED TO MODIFY IT SEEM TO BE WITHOUT ANY ACTION? HAS ANYONE HAD ANY RESULTS?
it doesn't work. on smarttool you need to input master ecmid before you add key. more complex than iprog plus. read - decode add key manually. works Big Grin
06-14-2026, 07:36 PM
05-16-2026, 02:58 PM
Audi
02-19-2026, 02:48 PM
