Porsche Technical Support Service, PPN Online
  • checking history of the car by VIN in the centralized database of Porsche
  • checking availability of open dealer campaign
  • car mileage
  • Wiring Diagrams
  • Technical documentation
  • VIN activation codes (factory) + retrofitting
  • removing SFD2 protection, resetting service interval, disabling Flight mode mode (relevant for 2023+ model range)
  • key programming service, removing component protection (possibility is discussed separately)
  • updating and adding language to PCM 6 (MIB 3) (Panamera  971, Taycan, Cayenne E3, Porsche 911 992 )
  • disabling  account of Porsche ID for PCM6 (guest account)
  • large database of firmwares and parametrics for electronic components, update firmware PCM6
  • E-Sim data: IMEI, ICCID (Connect service information) for Taycan, Cayenne E3, Panamera 971, Porsche 911 (992)
  • remote service Worldwide (additional information is required. equipment)
      Price list starts from 20 euro, if you have any questions, write to PM.
      ONE - Time service  (I don't sell accounts)
* remote diagnostics and repair service is available (service starts from 50 euro)
PPN service is available (ONE - TIME Service)
* Deactivating SFD2 protection  (Cayenne E3 PA, Panamera G3 Y1A, Macan EV)
- immobilizer
- component protection remove
- SFD 2
- factory codes  online
- factory codes with PPN (factory IPAS codes list)
I do not remove protection from used units from other cars,
blocks that were programmed through vvdi and other Chinese devices
immo - 500 euro
component protection - 400 euro
SFD 2 - 250 euro
factory codes  online - 350 euro
Thanks given by: garyr , Sawminmin , seok
prices added 1st post
Thanks given by: seok
NEW
SFD2 Panamera G3 YA deactivation available
disabling Porsche ID PCM 6 2022+ and 2024 + (Guest mode)
remote enabling Russian and other languages:  PCM6 , instrument cluster 2022+ and 2024 +
why used parts not supported?
Would you be able to activate a servotronic on a Porsche Macan S 2024? If yes, Can I send you a PM?
(09-19-2024, 11:50 AM)pittyxp Wrote: Would you be able  to activate a servotronic on a Porsche Macan S 2024? If yes, Can I send you a PM?
need vin
write to me at pm
(02-11-2024, 11:41 AM)Belauto Wrote: Porsche Technical Support Service
  • car mileage
  • Wiring Diagrams
- immobilizer
- SFD 2
immo - 500 euro
SFD 2 - 250 euro
  • car mileage
  • Wiring Diagrams
- immobilizer
- SFD 2
immo - 500 euro
SFD 2 - 250 euro
Hello friends send me your contact information
I have a taycan GTS from the USA, is it possible to change the high parameters in the conbox to adapt it to the Polish market.
I've already replaced esim in it with Polish sim and I have LTE on the wyfietla. But when I press SOS it calls service in USA.
Greetings
Piotr
Hi pls send contact information via pm. Tks.
