Porsche pdk programming with piwis 3
Hello all, I need some direction. I'm working on a Porsche 992 and one of the tasks is pdk calibration. I got a clone piwis 3 to do this. First go around, the calibration failed at the hydraulic part because there was an issue with a temperature sensor. Got that sorted (bad connection), cleared the code and the whole pdk wiped. I went into auto program and everything seems to have come back. VIN, version, etc. Tried calibration again but got a message "Function can not be carried out, thresholds not present or faulty" on the first calibration procedure. I ran the auto program again and tried calibration again and on the third try, the first calibration went through but i got the same error on the second calibration for the hydraulics. Any pointers which way to proceed?
(05-01-2024, 10:21 PM)Bolo3378 Wrote: Hello all, I need some direction. I'm working on a Porsche 992 and one of the tasks is pdk calibration. I got a clone piwis 3 to do this. First go around, the calibration failed at the hydraulic part because there was an issue with a temperature sensor. Got that sorted (bad connection), cleared the code and the whole pdk wiped. I went into auto program and everything seems to have come back. VIN, version, etc. Tried calibration again but got a message "Function can not be carried out, thresholds not present or faulty" on the first calibration procedure. I ran the auto program again and tried calibration again and on the third try, the first calibration went through but i got the same error on the second calibration for the hydraulics. Any pointers which way to proceed?
Hi , do you have other tools ?
I m using Topdon Smart phenix and it's working good on this gearbox .
Update Your Piwis Software...Your Piwis software out of date...
11-30-2024, 08:52 PM
Porshe
11-30-2024, 07:03 PM
Porshe
11-30-2024, 02:36 PM
