  • 7 Vote(s) - 2.86 Average
Problem Transistor BC337, galletto V54
Hi, I have a problem with a galletto v54 that I have modified all the components, galleto works well, kinea K, CAN, BDM etc, but the transistor BC 337, it gets very hot, to the point that you can not touch it, the voltages are Correct, I've changed the transistor and it's still the same.
Do you know what is due?
Thank you
Are u using 12v or 24v?
(01-16-2017, 09:39 PM)Simial Wrote: Are u using 12v or 24v?
12v, to be exact, power supply on 13-14v, other gallettos do not present that problem
hi measure the voltage on base and after on emiter tell me the values and i will help you base must is 0.7V over the emiter for example emiter 1.2V them base 1.9V at less 1.95 better.
Thanks, emiter 5.15v, Base 5.69v, Colector, 12.83v tension power supply 12.83v
(01-16-2017, 09:37 PM)queroseno Wrote: Hi, I have a problem with a galletto v54 that I have modified all the components, galleto works well, kinea K, CAN, BDM etc, but the transistor BC 337, it gets very hot, to the point that you can not touch it, the voltages are Correct, I've changed the transistor and it's still the same.
Thank you
you have a broken chip u7
regards
Thanks given by: queroseno
Thank you
regards
Thank you, know the reference to request it, for example in farnell?
emiter must be 0.00V tranzistor NPN in this case must is 0.00V colector is conected to rele coil? be carefull the base isn't to center look at link.
https://www.google.gr/search?q=BC+337&cl...55Tdb2M%3A
buddy this transistor operates in a different system here and emitter does not need to be grounded, works as a voltage stabilizer.
It is a stabilizer for u7
regards
02-24-2020, 06:25 AM
02-09-2020, 04:32 PM
02-09-2020, 03:32 PM
12-23-2019, 01:09 AM
