Problem automatic gearbox
I have a problem in the automatic gearbox of an audi car, it shows me the following error codes in the diagnostic tool
P179E
P179F
Can anybody help me
File Type: .jpg
Downloaded: 21 times
Hi
What’s the definition of the error codes. It easy to get help when the code definition is written.
Regards
P179E Sensor for range of gears - electrical failure
P179F sensor for range of gears - incorrect operation
try to basic setting and adaptation if always have same default maybe repair your mechatronic or change.
some audi have wiring harness inside transmission that goes faulty that need to be changed
if it is 0B5 transmission you have to change gear selector sensor unit inside gearbox.
Replace G676 http://www.audizine.com/gallery/data/559...Sensor.JPG and you will solve your problem.
If I helped you please press thanks and rep
Thank youNerd
Thanks given by: audi-li
#8
What type of gearbox?
Professional Audi repair, please contact me at [email protected]
  Automatic trasnmission dardilaunch 0 358 09-21-2018, 06:51 AM
Last Post: dardilaunch
Audi Gearbox issues with B8 heinis3 3 899 09-18-2018, 10:50 PM
Last Post: engert81
  VW GOLF EDC17C46 REPLACED ECU CODING FROM MANUAL TRANS TO AUTOMATIC TRANS pitstop0212 12 461 09-12-2018, 11:35 AM
Last Post: pitstop0212
Audi Gearbox Faults Audi a4 2008 Danico 6 186 09-03-2018, 03:41 AM
Last Post: sixcode
Audi AUDI A4 NO REVERSE GEARBOX MALFUNCTION Shawnp 16 262 08-12-2018, 06:07 AM
Last Post: davvid
