  • 9 Vote(s) - 2.78 Average
Problem with EIS 203
Hello Friends,
I have a Problem with a W203. i dont touch the car and i got it with this issue
it was in other service center and it ssems they was tring to fix issue in EIS
the Car can start but Windshield wiper doesn't work and the winker kepp blinking right and left
Maybe you know what the problem .
Thanks.
Use star diag and give more info if you want to get helped.
It doesnt sound like EIS problem ........
(03-16-2017, 12:32 AM)erron Wrote: Use star diag and give more info if you want to get helped.
it is EIS issue as i think ... after i replace the EIS with new one i dont see the issue with the Windshield wiper and winker but the care was not working because EIS is not compatible with the car
this is deffo eis problem.
(03-16-2017, 12:02 PM)mikeburnet Wrote: this is deffo eis problem.
Any idea how to fix
Any idea how to fix
Hello my friend. On this car, very often broken wires that go from the stalk switch to the block under the steering wheel. Tell me whether the parameters in the data indicate whether the turn is turned on or turned on.
They glass cover will not work if the door or hood is open I know this topic by heart can help. Only I'm from Russia and my English is bad
Thanks given by: nano
If your W203 is early version - model year 2000 or 2001 its defect may be in EIS or Rear SAM (2J74 problem - google). From 2002-2003 MY the reason of defect wiper- and turn- switch, or in moisture (electrochemical corrosion in control units & wirings), under - and overvoltage - see in STAR real data stream and errors.
