Problem with Opel Corsa Delco E98 dpf off
Hello, i have Corsa 1.3cdti with Delco E98 ecu. After i reset dpf values with autocom i make a dpf off file with Davinci. After some days the client called me and told me that there was a watning about full dpf in dash. I wass told that the problem was the reset by autocom, so i write ori back and this time i reset it with Tech2 of a friend. ( here maybe i should say thay when i make the dpf reser with both diagnostics the value goes to 70% ). I write file again and also disconnect diff sensor, but after few days the same message appeared. Can someone help me with a different dpf solution or tell me witch diagnostic can zero dpf values?
gm_delco_e98_obd_full_20221209143152_int_flash.rar
102
1.17 MB
[attachment=513470]
File Service
Stage 1 - 3 , MANUAL DPF , EGR , Adblue, DTC
Authorized Magicmotosport, Autotuner, Alientech, EVC Distributor
Thanks given by: KRS tuning , LOPEZ-TECH
Davinci original or cracked? In original Davinci all Ok.
Do not forget to press Thanks and Reputation buttons...
Orignal davinci delco e98 1.3 solution I’m not working
MAGIC User
AutoTuner User
(01-07-2023, 03:09 AM)agut808 Wrote: Orignal davinci delco e98 1.3 solution I’m not working
Write about the problem to the Da Vinci developer, and he corrects your file and then updates the BUG in soft.
I think all tools reset dpf on opel to 70% correct me if I'm wrong
yes , Launch have a promt to confirm this.
(01-06-2023, 09:07 PM)danielif Wrote: Davinci original or cracked? In original Davinci all Ok.
Original Davinci of course.
I sent to Backgroup but he didn t find the problem. Thankfully solved with the file that Jurevb sent me.
(01-07-2023, 01:13 PM)redchilly Wrote: I think all tools reset dpf on opel to 70% correct me if I'm wrong
Yes thats true. After Davinci developer told me that maybe dpf reset was the problem, i tried every diagnostic tool available near me ( included Opel dealers diagnostic tool ) and all reset dpf to 70%.
(01-06-2023, 04:41 PM)KRS tuning Wrote: Hello, i have Corsa 1.3cdti with Delco E98 ecu. After i reset dpf values with autocom i make a dpf off file with Davinci. After some days the client called me and told me that there was a watning about full dpf in dash. I wass told that the problem was the reset by autocom, so i write ori back and this time i reset it with Tech2 of a friend. ( here maybe i should say thay when i make the dpf reser with both diagnostics the value goes to 70% ). I write file again and also disconnect diff sensor, but after few days the same message appeared. Can someone help me with a different dpf solution or tell me witch diagnostic can zero dpf values?
in old shape opels cars was simal problem solution was change coding in dash, maby try
