  • 19 Vote(s) - 2.95 Average
Program ecu on a Smart fortwo passion 1999.
Hi, I have a old Smart fortwo 599 ccm. Its from 1999, and I have a Xentry 2014.09 on a Dell 630 with C3 diagnostics. The system seem to work AS IT should so, but when I try to update the ECU software I end up with a error message.
DAS reads the ecu and finds the firmwarenumber, and it says that The original is older than the new one. After I have turned off and on the Ignition three times when asked to, I get an error message.
Anyone know what to do? I have used the same system on the same Smart to teach in new keys, so it looks ok to me.
Its a Problem of youre das System.
There are different das Systems on this Forum but i dont know which of Them Supports Update for Smart. I have Same Problem since Update :/.
Try to find Update Firmware Elsewhere and Flash it with kess or galletto....
Tup If i helped you please give a positiv reputation by pressing----->[Image: reputa12.gif]
(12-20-2016, 01:48 AM)kast_ Wrote: Its a Problem of youre das System.
Is it possible with a older version og Xantry? 2012?
No mate... i think it depends on which methode of installatiin.
Got similar issue on Smart - solution -> connect the car battery to charger -> to low voltage to process data
the problem is not low voltage, is xentry install not right installed!!!
why need update the ecu? if not run ok can restore actual map?
if not not is very secure update the ecu!!
regards
(12-22-2016, 01:24 AM)audiomeca Wrote: the problem is not low voltage, is xentry install not right installed!!!
regards
The plan was to take a performance update.
brabus performance not run if not make scn when program the unit!!!, need dealer acount and change dates in vedoc to run BRABUS SB1
