Q: ODIS-E 8.1.3 6 VAS5054A - automatic car recognization possible?
is somebody able to tell me which options need to be taken, so that ODIS-E 8.1.3. recognizes carline automtically?
VAS5054A is not a DOIP Hardware, so recognioztion by DOIP is not possible.
ODIS-S 4.3.3 recognizes the car.
Does a work around exist for this automatic recognization in ODIS-E 8.1.3?
Thanks in advance.
Odis-E can recognize the correct car automatically when you have the correct and full compatible projects and the car is with Uds Ecu's...... Kolo
(Of course you must have and the correct configurations on the Admin panel.........)
For older cars (Kwp) in many cases you must select the correct project manually............
So in this case for to select the correct project you must make one fast diagnosis with Odis-S and then to see the ASAM project name from your saved protocol.........
Regarts........Beer
Thanks given by: Marcos , Jake5555 , diagnostix , danielgatan
#3
(10-12-2018, 08:27 PM)vagvag Wrote: Odis-E can recognize the correct car automatically when you have the correct and full compatible projects and the car is with Uds Ecu's...... Kolo
Regarts........Beer
Thank you for the explaination.
Helped me a lot to understand the how to.
Are able to tell me/us the correct configuration in the admin panel?
I will try it soon.
Thanks alot
Regarts........Beer
I will try it soon.
Thanks alot
Here................... Kolo
[Image: 6eoxo9.png]
Regarts...........Beer
Thanks given by: diagnostix , chcp , Jake5555 , Nabil77 , Marcos
#5
Regarts........Beer
I will try it soon.
Thanks alot
[Image: 6eoxo9.png]
And again.
Thanks.
This is what I wanted.
I will try it soon if it works.
have a nice day.
are these ticked as default ?
(10-13-2018, 11:20 PM)@[email protected] Wrote: are these ticked as default ?
Nop......... You must click and to enable them for to have deeper ecus tree and info......... Kolo
(If you know of course what you doing with the Odis-E!!!!!!!!!)
Regarts......Beer
Thanks given by: diagnostix , Marcos , Jake5555
VW ODIS-S 4.2.3 + Activation keys Open to everyone engine 2,870 92,418 1 hour ago
Last Post: barsatters
  Odis 4.2.3 Full All in ONE sixcode 971 31,428 Yesterday, 11:47 PM
Last Post: kikis
  Fix error ODS2522E for ODIS evol 7 309 Yesterday, 12:19 AM
Last Post: evol
VW ODIS+ELSA+TPI working together? MichaelGerasimov 1 126 10-14-2018, 05:27 PM
Last Post: Guss
  need help ODIS franrs4 1 92 10-14-2018, 03:10 PM
Last Post: Guss
