Question about old Renault diagnostic hardware
Hello, I have a question: What hardware do I need to connect to 1994 year Renault TWINGO 1.2 40kw Marelli ecu, engine code C3G 700 just to check live engine data and fault codes? Thank you for your answers.
(09-29-2019, 07:04 AM)Gerveliz Wrote: Hello, I have a question: What hardware do I need to connect to 1994 year Renault TWINGO 1.2 40kw Marelli ecu, engine code C3G 700 just to check live engine data and fault codes? Thank you for your answers.
You can use CAN CLIP with an old version of the software before V136. CAN CLIP sonde has to be RTL2002. The Renault tester at that time(1994) was ACTIA XR25. Use the diagnostic socket adapter to OBD.
Dont forget to use x86 W7 maximun, with adaptater plugged on fusebox.
05-30-2020, 06:04 PM
05-30-2020, 01:35 AM
05-29-2020, 12:50 AM
05-27-2020, 02:16 PM
05-25-2020, 12:27 AM
