Hi everyone,
I flashed a new ECU file using KESS: DPF and EGR are removed.
- In OPCOM, the EGR responds when I press the accelerator.
- The DPF still shows 496% filled.
- The car drives better now and no longer smokes heavily on startup.
- What should I do with the wiring from the DPF to the temperature and pressure sensors?
- What should I do with the EGR? Should I unplug it and block/plug it?
