  • 4 Vote(s) - 3 Average
R270 Modifications (All in one place!)
Hello everyone, my first post here. I have been using an R270 with these modifications for over a year now with 100% success rate.
I have done M35080, M350803, M350806, 080D0WQ, 160D0WT, and whatever CAS3 uses. 080D0WQ takes a minute or so to decode but it works. It does take quite a few tries for the R270 to be able to detect it though. When doing a CAS module, you need to use a hot air gun and keep it blowing on the processor. I have not had luck erasing M35080V6. The replacement, upgraded board may be able to do it.
Replace AH08 with genuine TI SN74AHC08DR (AH08) on main board.
Remove yellow capacitor on C1 on the adapter board.
Use a high quality 12V power supply
Replace 74HC125 with genuine TI CD74HCT125M96E4 on the adapter board.
Replace the capacitor on the main board with a high quality 10V 1000uf capacitor
Replace R11 on adapter board with 10k resistor.
Finally, when using the software, always select "No" during the "check pin state" popup.
Hopefully you find this information useful. I have also attached a working version of the software.
https://mega.nz/file/8tFmxYTa#4Tdtavf61T...aBQnLHY0aQ
I'm trying to get my r270 working currently. Main issue is it reads m35080 up to about 995/1024 and then it just hangs, unit beeps and goes inactive. I've tried my blank dq chips as well but same issue. Will try this and see along with the software. Quick question, are you running it on windows xp? I'm trying it on win10 in xp compatability mode but not sure if that's part of the reason.
(02-28-2025, 04:03 PM)dbbob1987 Wrote: I'm trying to get my r270 working currently. Main issue is it reads m35080 up to about 995/1024 and then it just hangs, unit beeps and goes inactive. I've tried my blank dq chips as well but same issue. Will try this and see along with the software. Quick question, are you running it on windows xp? I'm trying it on win10 in xp compatability mode but not sure if that's part of the reason.
Did you ever resolve this? I'm having the same issue - I have also updated the board with the components OP outlined but still no luck with it. After multiple attempts It will sometimes pass read and verify but always fails write
Do you know the value of the coil?
Users browsing this thread: mcm44
