  • 4 Vote(s) - 3 Average
RENAULT PREMIUM FAULT CODE
HAVE A PROBLEM WITH RENAULT TRUCKS GIVINR ME A 5301 ERROR CODE... SYMPTOMS INCLUDE LONG CRANK , LOSS OF POWER AND EVENTUALLY LOUD DIESEL KNOCK SOUND
I don't even know as Renault have premium faults ,sound like standard faults for basic models,and premium for more expensive models.WOW.
Sent from my SM-G955U1 using Tapatalk
Code error 5301 is Injection pressure too high
might be
1- faulty injectors or nozzles
check the amount of the return fuel from the injectors as specified by the manufacturer
2- Clogged fuel filter ( replaced )
I hope that might help you
Heavy Duty Mechanic
if my post helped you then don't forget to hit [Image: rate.jpg] & [Image: thanks.jpg]
Thanks given by: fatso3333
(05-30-2018, 06:09 AM)silnoreki Wrote: I don't even know as Renault have premium faults ,sound like standard faults for basic models,and premium for more expensive models.WOW.
Premium is a truck model
07-19-2019, 03:16 AM
07-03-2019, 09:12 AM
07-02-2019, 01:01 AM
Renult
06-18-2019, 02:47 AM
