30
Thanks Given: 1290
Thanks Received: 214 (156 Posts)
1,929
817
12-09-2017, 06:35 PM
Hi to all friends
How are you?
I have this problem with this radio
While the client was listening music suddenly the screen turned WHITE
I must say the the radio has sound in radio and works in \cd
where must be the problem pls
thank you very much
10
Thanks Given: 183
Thanks Received: 47 (28 Posts)
112
13
Hi, I must say I have the same problem with a rns510 with white screen, but the customer was in a hurry and take the unit from me before trying anything. Ive read that this problem can be caused by a hardware failure from the panel electronics. May be some hot air will help. Also I solve another unit with white screen which was in this state after a failed update, but this was a software problem and was solved by writing 2 flashes with the dumps from this forum.
0
Thanks Given: 15
Thanks Received: 6 (6 Posts)
22
white screen means there is no power to the scaler, check the power supply to the panel
viktorw
Location OfflineJunior Member
Thanks Given: 36
Thanks Received: 10 (7 Posts)
97
i have the same problem....could u tell where to find this problem on the lcd display board?
Reparing rns 510 /810 skoda Columbus
All firmware available
Setconfig, rns manager
Martech box
Vcp
Vcds
Rheingold bmw
viktorw
Thanks Given: 36
97
No not yet
Martech box
Vcp
Vcds
Rheingold bmw
