Range Rover Sport L320 from 2010 coding new key using SDD
Hi, I just bought a new key from the dealer which requires coding.
I load up SDD v139, but when I start up the coding a new key function I get the following error message:
"the keyless controller installed on this vehicle is incorrect, please check part number which should be BJ32 or DPLA".
I have no idea what's wrong, since the keyless is working perfecty with my other spare key.
This is a known issue with JLR. Essentially what happened is that the original KVM will not accept programming of new keys for whatever reason. Land Rover has posted a bulletin about this and the fix is to install a new KVM. Google search Land Rover bulletin LTB00540 (version 5 if you can), it will give you the part numbers and details.
BTW: passive entry vehicles have a button on the handle (square, black), non-passive vehicles do not.
Thanks given by: KriyenKPp , ljbp
#3
Thank you. Very helpful.
Land+Rover Range Rover Sport turning off TPMS JohnyNYC 4 146 4 hours ago
Last Post: jkoli
Land+Rover SDD 145 activation problem phydor 3 222 10-13-2018, 11:29 AM
Last Post: nek13
Land+Rover Range Land Rover Velar L560 Dynamic Xenon Matrix Led Headlight J8a2-13w030 XL19 kentrinite 0 106 10-13-2018, 03:09 AM
Last Post: kentrinite
Land+Rover Range Rover L322 MY. 2010-2012 CCF editing Donnie 9 184 10-12-2018, 08:23 PM
Last Post: nick2509
Land+Rover 2003 Land Rover Discovery 15P jjmotors 3 174 10-12-2018, 05:42 PM
Last Post: ncapela
