Rate/check tune VW Scirocco 1.4 TSI
Can someone check this tune for me? It´s a 2008 VW Scirocco 1.4 TSI
Power is good but the car stutters while accelerating at about 3.000rpm
I can not find the mistake and I want to rule out, that it comes from the file
thanks
VW 1.4 TSI.zip
File Type: .zip
Downloaded: 20 times
with stock file works good? does it has manual gearbox or dsg?
thank you
ADF Tuning CHIPtuning/ECOtuning/DSGtuning
100%tested DPF EGR ADBLUE LAMBDA TVA VSA EVAP CAT DTC errors delete
skype:adf-chiptuning / whatsapp ask me by pm
Car, Bike, Agriculture, Bus, Truck, Marine
(09-14-2018, 05:32 AM)adf-chiptuning Wrote: with stock file works good? does it has manual gearbox or dsg?
thank you
with stock file it´s too but barely noticeable
manual gearbox
is the same problem in stock file or after remap?
Remap/DPF/EGR/FLAPS/DTC...
File Service 24/7
Database for original ecu files
Damos map packs!
Make dynamic logs and post it.
(09-14-2018, 05:25 AM)ROVERDIESEL Wrote: Can someone check this tune for me? It´s a 2008 VW Scirocco 1.4 TSI
thanks
Try lower your request torque and Engine load below 3000 rpm.
VW VW Passat 1.9TDI AVB - rate my tune mihau 20 946 4 hours ago
Last Post: RacingMNE
Ford Ford Transit 2013 sid208 egr off check light blinking malamadre 2 199 Yesterday, 09:34 AM
Last Post: Obd4diagnose
  file check vagnum 0 70 Yesterday, 07:13 AM
Last Post: vagnum
  opel vivaro 2.0 2007 egr off please rate yanko 7 308 09-22-2018, 08:36 PM
Last Post: yanko
Alfa Alfa 159 DPF off file check euromod 7 219 09-22-2018, 05:42 AM
Last Post: euromod
