Read S210 E320 CDI
Hi @all!
Tried to read my E320 CDI (OM613 / EDC15) with Kess V2 Clone. Used the OBD2 Cable + OBD2 to 38 Pin adapter but can't read / identify the ECU?! Which cable should I use for the 38pin connector?
Any help would be appreciated!
Thanks in advance!
K-TAG direct connect.
(07-02-2019, 02:24 AM)evgenijj Wrote: K-TAG direct connect.
edc15 is KWP most of them when you write from 38pin they kill 29f800.better to read with programer.safe.
ECU-REPAIR-KEYS-IMMO-ABRITES FULL MERCEDES-ALFA-PSA  GROUP-VW-ORIGINAL XPROG-UPA ENIGMA-MANY OTHER
Every days a schoolday
Thanks for your replies! So I‘ll try with kess at the bench as next step.
I fixed the OBD2 - MB 38Pin adapter: Had to switch 2 cables. Currently working perfect via OBD!
Easy 4 pin in diag connector this mb is Kline
7 from kess to 4 mb connector
16 to +
4 and 5 to -
And go
05-26-2026, 03:34 PM
