Here is a little tutorial to succeed in reading an eeprom of the 95xxx series for cheap with a ch341a
1: The eeprom needs to be supplied with 5V for this it be necessary
- Connect pin 5V to pin VCC(+) which corresponds to location 8 of the 95xxx eeprom pin in the connection part 25xxx (BIOS)
- Cut or raise the middle pin of the voltage regulator (see picture attached, this is the black block with 3 pins)
2: Download software that can read the eeprom, for this you will have to go through the software ch341a program V1.29 and configure it on the bios 25LC160.
I put two pictures as attachements.
For software do a google search with " ch341a programmer 1.29 download"
I find this site http://karadev.net/basto/CH341A-programm...ware-1.29/
You can download the V1.29
Good luck
and do not hesitate to put "thank" ^^
Good luck
