  • 5 Vote(s) - 2.6 Average
Reading mc9s12hz128val Captiva
Hi guys I am trying to read a Captiva cluster with mc9s12hz128val MCU. I have X prog 5.5.5. the connections xprog is giving are different from the one on the MCU datasheet. Can someone confirm good pinouts please?
here for you.
thanks+rep
captiva hz128.rar
35
278.97 KB
Thanks given by: Tunc Onder , ryn079 , velindro , RallyeS2 , seva
Thanks, but my connection is labelled as j2. Also when I try to probe the reset pin on the mcu to the connection I get no continuity. Can someone advise please?
Can please someone confirm the following for mcu connection please?
35- vss
36 - vddr
39 - bkgd
40 - reset
As my xprog is showing totally different connections.
try this
captiva 9s12.rar
23
840.76 KB
guys, my mcu has 3l16y mask. my xprog does not list this mask. is there a way out?
That is 9s12HZ256 so there wont be problem for Xprog if you have good one.
(06-01-2018, 02:27 PM)pepi Wrote: That is 9s12HZ256 so there wont be problem for Xprog if you have good one.
MCU is mc9s12hz128val
Could someone advise please?
Chevrolet
10-21-2019, 06:40 PM
09-30-2019, 10:06 PM
09-27-2019, 10:03 PM
09-23-2019, 07:33 PM
