Rear camera cover module W253
Hello colleagues! I have a problem with the GLC250d W253. I bought the car with the problem. The car has a 360 camera and active parking assistant. The problem is with the rear camera. All the others work normally in 360 mode and when parking. When I start the car, the rear camera opens, and when I engage reverse gear, it shows an image for a second and then the cover closes and gives a black screen. When I turn on the parking cover, the cover opens again - it works in reverse. There is an error recorded in the camera cover module that the mechanism is blocked. I replaced the entire mechanism with a new original one from Mercedes and it's still the same. It doesn't recognize the open-closed positions of the cover.
If I have helped you, don't forget to give me a reputation, thanks! Drive
If you replaced the mechanism with a new one and it's still the same, it's possible the problem is in SAM-R... try to update it
Is the wiring reversed?
(08-07-2026, 12:03 AM)koki_kolev Wrote: Hello colleagues! I have a problem with the GLC250d W253. I bought the car with the problem. The car has a 360 camera and active parking assistant. The problem is with the rear camera. All the others work normally in 360 mode and when parking. When I start the car, the rear camera opens, and when I engage reverse gear, it shows an image for a second and then the cover closes and gives a black screen. When I turn on the parking cover, the cover opens again - it works in reverse. There is an error recorded in the camera cover module that the mechanism is blocked. I replaced the entire mechanism with a new original one from Mercedes and it's still the same. It doesn't recognize the open-closed positions of the cover.
Yeah like You said its mechanism issue probably its wrong mounting. I had it on on x290 had to remove bumper couple of times. Exactly same symptoms
All brands support remote programming
Contact info in Bio
Try activating it outside its housing to ensure it reaches the end of its travel.
It would be useful to know the DTC it is throwing and in which module.
I forgot to mention that the cables have been checked. I tried to reverse the motor cables, but then it works normally but the error about the blockage still exists. The motor reaches its end positions quite normally. The error is recorded in the electronic unit of the camera cover cpf _222 and is -B1FF471 The camera cover has a malfunction. The actuator is blocked. This is not controlled by the REAR SAM. Also the CPF222 module has been reprogrammed with MONACO
It behaves the same with the mechanism installed and without it being installed, just hanging on the cables.
(08-07-2026, 02:09 AM)Росинант Wrote: Окабеляването обърнато ли е?
The wiring has been checked according to the diagram and it is correct. I tried to swap the polarity of the motor, it started moving as it should, but I still get an error and the camera turns off.
