  • 7 Vote(s) - 3.57 Average
Replace CarProg MCU?
While attempting to solder a lead to pin 55 of my CarProg's MCU, pin 55 sheared off from the MCU. I am wondering if I need to purchase another CarProg from eBay or if I can just get another Amtel MCU. Any help would be appreciated.
Main unit of carprog on aliexpress is about 35$
(08-31-2015, 06:23 PM)ruffles1986 Wrote: Main unit of carprog on aliexpress is about 35$
My hope was that the Amtel MCU would be available for purchase for less than $35. Also, if I can find an Amtel MCU by itself, I don't have to spend time de-soldering the MCU, lifting pin 55 and re-soldering the MCU, I can just lift pin 55 and solder the MCU to my CarProg.
I bought 5 MCU for about 15GBP from aliexpress.
And in procces broke 2 more. Third one was ok. and still 2 left
Mcu came well packed in plastic housings and programed straight away with J-Link
.txt
MCU.txt
260
98 bytes
Known as Dziwak77 or Tomski Call
41
Thanks given by: Deviant0ne
get a dremel type tool and grind/sand the silicon very very carefully were the leg broke off, you will reveal some more of the leg under the silicon (dont go too far in, you just need a little edge to solder a wire to).
hope this helps
Please use THANKS and REPUTATION if my post is helpful...
Thanks given by: Tomski , Deviant0ne
(09-01-2015, 01:25 AM)Tomski Wrote: I bought 5 MCU for about 15GBP from aliexpress.
This is exactly what I was looking for!
(09-01-2015, 04:43 PM)Domelec Wrote: get a dremel type tool and grind/sand the silicon very very carefully were the leg broke off, you will reveal some more of the leg under the silicon (dont go too far in, you just need a little edge to solder a wire to).
hope this helps
Brilliant! I was able to un-cover a small amount of pin 55 and I think I'll be able to re-solder the MCU and the lead off of pin 55 without issue.
Glad to have helped Smile
10-13-2019, 11:03 PM
10-05-2019, 04:20 AM
09-23-2019, 11:27 AM
09-23-2019, 01:57 AM
09-16-2019, 06:42 PM
