(12-13-2016, 03:14 AM)EASatlanta Wrote: Mine is different.... I click the hhtpkw file, it does the same thing.
Just sits there working... nothing opens. DAS says it opens HHT. This is a drive problem I foud out with my motherboard
Gigabyte z170n wifi.... good new board but not compatible with TONS of stuff.... I have to change it for HHT.
Irik: For yours, you need to run openshell patcher and apply HHT, otherwise you need to point DAS to hhtwin directory
I allready run Xentry.OpenShell.HHT from DieTRih and how can I point DAS to hhtwin directory?
If I helped you, please press
and
thank you!!!
and
thank you!!!
