  • 25 Vote(s) - 3.28 Average
SD C4 Install guide + error fixes win7
Hi all
I hope this guide will shed some light on how to install C4 software.
First of all, you'll need proper software, this "guide" i will explain how i managed to install software.
You'll need this:
- Rar files is attached with torrent link
Das / Xdos / openshell 2016.09
EPC 2016.02 or newer
WIS 2016.02 or newer
Password: FreeShare
Also you will need some tool that can create a key for DAS / xdos
First of all, install openshell, when done you're able to install ewa net server, and then by using ewa net server you can install epc and wis database.
EWA net guide will be included in epc or wis software, if you can't find i will provide here.
ERRORS:
Cal 870 - you'll need to download a cal 870 fix and replace in DAS / BIN <- folder.
- If you have problem, please write here and i will upload a cal fix.
Error is caused because mux id is different from program, sometimes because of blacklist.
Internal error 3.17
You'll have to acces c:\programdata\licdir - in there you'll find a .dll file called lic_key_2.dat <- take this file, copy to desktop - rename it as:
lic_key_2.x4711 <- make sure this file is READ-only (right click, change properties)
Cut/copy file and put back to direction c:\programdata\licdir
This should end the fault.
"device is not in use" error
This is because the C4 is using static ip address when reading, so you'll probably never experience fault while using lan cable, but will happen using wifi - WIFI fix will come here later
KEYS:
Ask here for das / xentry key.
Wifi setup: WIN 7
Connect C4 to power supply, and connect lan cable to unit and pc.
Make sure c4 and computer is linked and are connected - go to networks.
Shuffle around on C4 and notice the mux's IP address something like
192.168.x.xxx
Go into folder; sdconnect (das) and run SDconnect toolkit/administration
At left site you should be able to see that mux is connected, then go to register/configure
And check the box "wlan parameters - road"
Make sure IP address is the same as your mux
192.168.x.xxx
255.255.255.0
Call the SSID:
Road24h
ENCRYPTION: WEP/HEX
Key: 26xa
aaaaaaaaaaaaaaaaaaaaaaaaaa
Press start button, a new window should appear, just press OK.
After this go to networks, and create a computer-to-computer network called
Road24h, make sure encryption is WEP and code is 26xa = aaaaaaaaaaaaaaaaaaaaaaaaaa
Go to wifi settings on wifi card and change IP address to:
192.168.x.xxx
Make sure that the first 3 sections is the exact same, the undernet mask is telling you that every parameter called "255" and so on NEEDS to be the exact same..
When you're all done, log into road24h on computer, and restart mux, mux will do a search and connect with computer.
Take care Smile
Xentry 2016.09 Torrent.rar
93
62.33 KB
EPC 2016.2 Torrent.rar
52
65.61 KB
WIS 2016.2 Update Torrent.rar
59
16.12 KB
CAL 870 fix.rar
211
473.76 KB
CAL fix 050511.rar
169
40.49 KB
XENTRY 2016.12.rar
159
66.35 KB
Xentry 2016.12 cal csl blacklist.rar
158
54.15 KB
Files added
-> Xentry 2016.12
-> cal fix 870 (edit date 0610 2015)
-> earlier cal fix (edit date 0505 2011)
Thanks given by: Rocinante , John Lee
Hello, I can not insert the license.
SC00003E error.
invalid license.
HD Hardware 4E6D080A40F4
App ID 252
  someone can generate license for me?
Thank you
(11-13-2016, 02:21 AM)Laegaard Wrote: Hi all
You'll need this:
Password: FreeShare
ERRORS:
Internal error 3.17
KEYS:
Wifi setup: WIN 7
192.168.x.xxx
192.168.x.xxx
255.255.255.0
Call the SSID:
Road24h
ENCRYPTION: WEP/HEX
Key: 26xa
192.168.x.xxx
Take care Smile
pijey
XBEG53ZGQ5AM473DHU3SVBHRRKNBK7HE2WH8E684KD6K4ZRKWPBFJSJQ9HCPY2GSPUF25X8JNS7F8RBCRT56NFPWJ325LSNX64MX5H2Q8UUZCKRTPB6837E5TAE7MTCFNN
(12-14-2016, 03:05 PM)Laegaard Wrote: pijey
the same, problem
You'll have to add cal 870 fix then.
open startkey center, enter license key press ok. DONT CLOSE
then open xentry / das. It should now open, when you're in the program close startkey center.
Just to add to your fabulas post, For wireless setup it is not enough.
Set your wireless ip address to 192.168.2.xxx sub-net 255.255.255.0
Assuming you set your C4 mux to 192.168.2.xxx (different then wireless ip) sub-net 255.255.255.0
reason for this, most of the router at home are set to 192.168.1.1 in your home and all your device ip 192.168.1.xxx. So, you are on a separate network and limiting the the contention window. CN put a really cheap B/G wireless card in the C4 Mux. I changed mine to N/A 5GHz.
1- Right click on network icon> open network sharing center> Manage wireless networks
2- Click on "Add"
3- Select Create an ad hoc network>next
4-Network name "Road24h"
5- Security Type "WEP"
6- Security Key is 26 times a (aaaaaaaaaaaaaaaaaaaaaaaaaa)
7- Click on Save this network > next
Now you gonna see the Road24h network on your list.
8- right click on Road24h> properties
9- edit the security keys to aaaaaaaaaaaaaaaaaaaaaaaaaa
Next-
Click Start>Accessories>right click on “cmd”, choose run as Admin
In the Command Prompt, type in
netsh wlan set profileparameter name=Road24h ConnectionType=IBSS
Close CMD window
Click Start>Startup>Right-click an empty space and click New > Shortcut.
Type in
netsh wlan connect Road24h
Name it as you like, may be crazynet.
Now Road24h is always there and s soon you boot C4 and PC, they are connected.
You'll need this:
Password: FreeShare
ERRORS:
Internal error 3.17
KEYS:
Wifi setup: WIN 7
192.168.x.xxx
192.168.x.xxx
255.255.255.0
Call the SSID:
Road24h
ENCRYPTION: WEP/HEX
Key: 26xa
192.168.x.xxx
Take care Smile
Thanks given by: Laegaard , AX-9 , dinho
(12-14-2016, 03:15 PM)Laegaard Wrote: You'll have to add cal 870 fix then.
I have done install from thy iso
Question: maybe I should make other changes
before starting setup?
excuse my English.
Thank you
Thanks for add-in. Tup
I also followed beneath steps, but i still have issues using wifi when diagnosticing. C4 needs static ip address to function, and i find it very annoying that i have to edit my laptop wifi ip address everytime i need to use the c4. I'd like to use laptop for working and diagnostics.
(12-14-2016, 03:57 PM)crazy40 Wrote: Just to add to your fabulas post, For wireless setup it is not enough.
2- Click on "Add"
Next-
Close CMD window
Type in
excuse my English.
Thank you
No worries, did you solve it? Have you fixed files in licdir folder?
