  • 14 Vote(s) - 2.93 Average
SDCONNECT losing wifi constantly??????
I've come across this problem which i can't resolve!. WIFI signal randomly loses SD C4 and then comes back instantly. Its a big issue when you're doing SBC system or something because half way through it loses wifi signal.
I have tried:
1. x2 different SD connects HQ and MQ
2. x2 different softwares 03.2016 and 12.2016
3. different WIFI card inside the D630 (2 pin one and 3 pin one)
4. Different wifi card inside the SD C4 (netgear and original G650)
5. Tried DISABLE then ENABLE with WLanRoamingEnable.zip
There is nothing else to change?!. But it can't be 2 faulty multiplexers with EXACTLY the same problem from 2 different suppliers!.
D630 is 3 ft away from the SD C4 and signal bar is full. But it loses signal randomly, then reconnects within 20 seconds.
Use a PCMCIA wifi card in the D630.. its a know issue that the connector for the built in wifi card comes loose from the motherboard in the laptop..
Thanks given by: Floryn_P , baner , j4g3d , 2007RennTechSL600
(02-03-2017, 12:38 AM)Rocinante Wrote: Use a PCMCIA wifi card in the D630.. its a know issue that the connector for the built in wifi card comes loose from the motherboard in the laptop..
+1 vote for this advice,
maybe is better idea to try with some other laptop, D630 is really outdated this days. I bet that it is at least 10 year old. Itwasntme
Regards! Drive
Thanks given by: j4g3d , Rocinante
Its true that we must shy away from D630 now since the serial port is not needed anymore.
What do you recommend?.
I've used E6420's which seem good, but the LAN port is in a stupid position on the corner, which can damage easily.
I use E6510 but same place for the lan cable.. but I only use the cable to set up the MUX, then its wireless for life!! Smile
(02-02-2017, 09:19 PM)j4g3d Wrote: I've come across this problem which i can't resolve!. WIFI signal randomly loses SD C4 and then comes back instantly. Its a big issue when you're doing SBC system or something because half way through it loses wifi signal.
I have tried:
Did you create the ad-hoc connection correctly?
Otherwise you have exactly this error ... Nod
If i could help please press "Thanks" and "Rate" button 049
I have tried:
Normally what i do is:
1 Go into administration of sdnetcontrol and set SSID, IP, WEP/HEX and put 26xa's
2.Then i go to adapter then set the static IP.
3.Then i manually create a ad hoc putting all these settings in.
4.Then i go to cmd and type "netsh wlan set profileparameter name=Road24h ConnectionType=IBSS"
Then of course set up startup to make sure it turns on when windows loads.
Correct?
Which OS win 7?
(02-03-2017, 10:32 PM)laco210 Wrote: Which OS win 7?
yep
