(10-25-2020, 04:28 PM)pesona Wrote: to be used for das offline programming, look at the post #34
Hello Pesona, I am really grateful for your work on Mercedes.
I have Xentry Xdos 03/2021. I am trying to do Offline programming. I have changed the Flashen folder to FlashenORI, then downloaded the Flashen folder
in place. I have put the simple batch file on the desktop to switch between Offline and Online. Now I have the option of Online and most important Offline
when I go through the coding software.
When I run Xentry/Das in Simulation Mode, of Model 221.171 of year 2007, near the end, I get the error you see in attached pic. Am I getting this error because
I am in Simulation Mode? - I do not have a car here to test! I am simulating changing one Rear SAM module for a new one. Any ideas what is causing this?
Another question please, regarding Flash Files:- The Flash files are for programming, right, not for coding? Or do I require them for the above coding I am trying to do?
I have copied into my 03/2021 installation the SDflash/Release from a 2015 installation, with is about 8GB in size. Is it Okay to do this?
I am as always, very grateful for any help you can provide to my above quesrries.
Regards
