edliu
Location OfflineJunior Member
Thanks Given: 140
Thanks Received: 11 (8 Posts)
56
21
Hi Guys,
I have a problem about SDconnect Toolkit COM-Server has stopped functioning.
May I ask how to solve this problem.
BTW, OS:WINXP
Thanks.
378
Thanks Given: 1085
Thanks Received: 2098 (628 Posts)
982
13
Have to be displayed some error code. What is installed only DAS/Xentry system or also some other software?
378
Thanks Given: 1085
982
13
05-05-2016, 02:35 PM
(This post was last modified: 05-05-2016, 04:33 PM by laco210.)
I think this is because DTS Monaco have own Ecom toolkit /2.1.4.2/ installed together with software and if you have installed another toolkit for sdconnect there is little war between this two toolkits.
[attachment=127053]
I have installed DTS on non DAS/Xentry pc and I have installed SDConnect toolkit 2.1.3 independently /because I don´t now how to make connection between original ecom toolkit from dts with sd connect I can not open administration for original ecom toolkit it said device will be connected automatically and I can not open it manually/ and sometimes is problem with Com-server error code 891 but is no problem with communication with SDConnect. I have it on win7 and I can start 2.1.3 toolkit administration or selection from icons on desktop if not working from icons in taskbar but now also working from taskbar I have set for both toolkits the same language and working from taskbar icons too.
Thanks Given: 646
Thanks Received: 62 (43 Posts)
224
21
how to solve this probleme
thanks
Thanks Given: 76
Thanks Received: 55 (19 Posts)
51
same problem here, i installed monaco on two systems with xentry xdos (12.2015 and 05.2016) and now the sdconnect toolkit is not working anymore.
the solution from mikedio did not work for me right now,
but it gave me some ideas that i will try.
