SEAT Leon ABS Long coding help needed!
Hi all, Could somebody with good knowledge of VAG long coding help - Here's the situation:
Customers car came in for ECU replacement - PCR2.1, this was done with SMOK X-can with no issues, BUT previous repairer had had a go at doing something and wiped the ABS coding & stereo code, so I have tried to recode pump as best I can using LCODE & VCDS using 'eng-mk60ec1.xpl' file found on this site and it worked a charm, but I do not know the exact coding & I'm not sure if its perfect - theres no fault codes now & hill assist etc are working fine, pleeeeeeeeease could somebody with more knowledge check for me & see if its correct & even better if somebody is able to get stereo PIN from VIN to save me pulling it out & doing it by eeprom that would be great, thanks for reading this far!!
Vehicle details:
SEAT AROSA
VIN = VSSZZZ1PZCR019821
ABS CODING (MY ATTEMPT) = 133B401209230003C81302E6901A0091350800
VCDS Log attached (Fault codes have been cleared since scan)
Log-DE61KDO-VSSZZZ1PZCR019821-99186.rar
4.1 KB
Please hit the reps & thanks buttons if this post was helpful!!!!
Jaycee230 Wrote:Hi all, Could somebody with good knowledge of VAG long coding help - Here's the situation:
Vehicle details:
SEAT AROSA
good job
u need to change just 2 bytes
133B201209230003C81304E6901A0091350800
Thanks given by: Jaycee230
Yesterday, 03:35 PM
06-12-2026, 07:10 PM
06-09-2026, 03:30 PM
