63
Thanks Given: 205
Thanks Received: 504 (224 Posts)
755
209
07-13-2024, 07:09 PM
(This post was last modified: 07-16-2024, 12:06 AM by Sweaty.)
Customer brought me two dashboards for ASTRA H. Original is completely dead, and second is working. I know how to read PIN so I could adapt it to his car, but the problem is, car is quite a long way from me, so I was thinking that I could just swap eeproms ?
Is the EEPROM on those somehow married with MPC ? Can I just swap eeprom and car will start ? Or do I need to go to the car and make the proper unlock and programming with second cluster ?
123
Thanks Given: 176
Thanks Received: 333 (281 Posts)
571
37
it should fire up
Hit Thanks and Rep button if I helped
670
Thanks Given: 224
Thanks Received: 1408 (399 Posts)
1,122
193
It should work
63
Thanks Given: 205
755
209
I swapped the eeprom, when I connected power on bench, I could see original mileage, so at least I think it should go smoothly. I'll know on Monday if it worked. I'll provide feedback when I hear from customer
1,225
Thanks Given: 249
Thanks Received: 2238 (930 Posts)
2,448
38
(07-13-2024, 09:17 PM)Sweaty Wrote: I swapped the eeprom, when I connected power on bench, I could see original mileage, so at least I think it should go smoothly. I'll know on Monday if it worked. I'll provide feedback when I hear from customer
if same hardware sw version,eeprom 080D0DQ enoph
mercedes retrofit,coding,programming,AMG menu,CARPLAY
FORD (remote coding programming) help
opel Coding programming help
JLR services
63
Thanks Given: 205
755
209
Second cluster had slightly different number. Hardware inside was practically identical. Main difference was EEPROM, one had 080DW and second had M35080VP. But I just swapped them and car is working fine. Customer called and told me that it fired up on the first try, everything is working like it should
