Thanks Given: 149
Thanks Received: 84 (42 Posts)
206
41
10-19-2016, 11:12 PM
(This post was last modified: 10-24-2016, 09:36 AM by felsch007.)
Hey guys,
I need your help. A customer has a 2013 E350 W212 with tire pressure sensors in his summer wheels. His winter wheels are without this sensors.
Is there a way to deactivate the pressure control via Xentry or vediamo?
I tried it in cgw212 but I can not connect to it. In ic there is no option for the sensors.
Thanks in advance!
Greetings from Germany
Felix
505
Thanks Given: 207
Thanks Received: 1104 (147 Posts)
301
39
I help you, connect sd to car and send me teamviewer id and pass
251
Thanks Given: 329
Thanks Received: 624 (280 Posts)
649
11
I made it by changing datacard and then scn coding
Thanks Given: 149
206
41
Thanks a lot for the offer, car will be back in the workshop on Saturday morning... I'll write you a pm! Maybe you can give me a little tip for it
42
Thanks Given: 248
Thanks Received: 198 (87 Posts)
173
21
10-19-2016, 11:28 PM
Start vediamo, select the files and folders mersedes benz xentry (maybe your old file cgw why not see) Go to cgw212 or 204, find the code 477 and change it.
Thanks Given: 149
206
41
Alright, thanks! I'll try that and will report!
Thanks Given: 149
206
41
Hey guys,
Car was back in my workshop today. I selected F:\Programme\Xentry\MB_PKW\Caesar\cbf then I chose CGW_212. Vediamo gave me an error and suggested to start an automatic ecu search and gave me CGW231 as the right module. I connected to the module, did the security access and changed the coding of the tire pressure sensors to not aviable.
Everything works now as it should! No more blinking lights in the display!
Greetings Felix
