SPS Backup Car
Hello everyone, is there a way to make a backup of all control devices in your car using Online SPS? If yes how? When I open my control devices, SPS reports that everything is already up to date and does not upgrade and therefore there is nothing in the Cahce folder. Thanks
There is no way to make a backup. If your ECU‘s were not up to date you can only make a copy of the last calibrations. But that’s not in your case. You can only do a backup from ECU, TCM and BCM with I/O Terminal for example.
Hello, thanks for the Answer.
Also is there no chance to Reload the Modules to get the Calib Files into the cache Folder?
Which car you need the backup
Astra K
(07-16-2024, 01:30 AM)Astradriver1983 Wrote: Astra K
Yes it is possible get calibrations using simulator.
hi
[font="Fira Sans Condensed", Calibri, sans-serif]what simulator can be use? [/font]
[font="Fira Sans Condensed", Calibri, sans-serif]Thanks[/font]
05-04-2026, 07:59 PM
Opel
04-24-2026, 02:40 AM
